1. cane prevost1's Avatar
    Did some research and still can't quite understand the band issue with T Mobile. I know they use 1700 and 2100 for fast 3G and sometime use 1900 if the towers have been refarmed. I contacted Blu for help with the best phone for T Mobile and here's what I got
    "In order to take advantage of the 3G/4G speeds make sure you have the appropriate model. All devices whose product number ends in “a” support 3G/4G at 850/1900MHz . Devices that end in “i” support 3G/4G at 850/2100MHz. Models whose product number ends in “l” support 3G/4G at 850/1900/2100MHz and models that end with “u” support 3G/4G on the 850/1900/1700MHz. Make sure the service provider uses the right 3G frequency for your device and that the proper APN (Access Point Name) settings are set."
    Based on the above info I should be pretty set with any of the Blu "u" models? Thanks!
    11-05-2014 09:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! That should work. Here's T-Mobile's official support page discussing its bands: T-Mobile network coverage | T-Mobile Support
    11-05-2014 12:04 PM
  3. cane prevost1's Avatar
    Thanks much! I've seen the T Mobile doc before. It's just a bit confusing as manufacturers don't often label the same. It seems that sometimes they say 1700 when the mean 1700/2100.
    11-06-2014 11:38 AM
  1. Replies: 12
    Last Post: 11-06-2014, 07:53 AM
  2. Replies: 1
    Last Post: 11-05-2014, 09:15 AM
  3. issue with note 4 and android central app
    By droid747 in forum Samsung Galaxy Note 4
    Last Post: 11-05-2014, 08:49 AM
  4. Replies: 1
    Last Post: 11-05-2014, 08:37 AM
  5. Replies: 0
    Last Post: 11-05-2014, 08:08 AM
