1. taicman's Avatar
    i did factory reset , does not work
    please help
    11-05-2014 10:16 AM
  2. Roman1's Avatar
    Try to restart the router, check the settings (encryption should be used WEP, WPA / WPA2-PSK). And disable the firewall.
    11-05-2014 10:43 AM
  3. taicman's Avatar
    i don;t think the router
    it does not pickup any listing of surrounding wifi
    thanks
    11-05-2014 04:08 PM
  4. Rukbat's Avatar
    Make sure wifi is on. (If it's not picking up any signals, there's about a 0.01% chance of its being your router, unless your nearest neighbor is more than 1/4 mile away.) Thrn the phone off. Not restart, power off. Remove the battery. Let it sit for about 5 minutes. (That's to reset the hardware, in case there's any residual power left after you turn it off.) Replace the battery, turn it on and try turning the wifi on again.
    If that doesn't do it, bring it to your carrier's store for help (and possible replacement - there's a year warranty on it).
    It sounds to me as if the wifi radio went south. (That's one problem I've never seen with a Note 3, but it can happen - even as soon as a day or so after you get it.)
    11-06-2014 01:14 PM
  5. taicman's Avatar
    it is in shop now
    no solution
    even change the wifi chip
    11-06-2014 02:22 PM
  6. Rukbat's Avatar
    If the shop is good, they'll figure it out. If not, they'll just replace the motherboard.
    11-07-2014 12:00 AM
  7. taicman's Avatar
    they cannot fix it
    has to replace motherboard
    problem they open it and i still have warranty
    i think once open it
    i lose the warranty
    i do not how much the motherboard
    thanks
    11-08-2014 09:23 AM
  8. Rukbat's Avatar
    If the shop is an authorized shop, you still have the warranty.
    If it's still under warranty it doesn't cost you anything.
    11-09-2014 12:02 PM
  9. taicman's Avatar
    now the bluetooth is not working
    wifi and bluetooth next each other
    if out of warranty, are they going to fix and charge
    11-11-2014 02:03 PM
  10. Rukbat's Avatar
    If they opened the phone, the warranty - from them - for anything that broke after that started at the time they first opened the phone. They can't break things, then tell you to pay them because the original factory warranty is gone. That's fraud, at the very best.
    11-12-2014 05:33 PM
  11. Vivek Sharma16's Avatar
    i had that same prob. i have note 3 n9005 and i update from sammobile and then no wifi
    but i solve this probl if u face still then write me i will give u tips
    05-26-2016 07:05 AM
  12. Joseph Fields's Avatar
    How did you fix the issue?
    06-05-2016 03:22 PM
  13. Vishnu Mishra's Avatar
    I am having the same issue, can you please advice ?
    09-16-2016 02:17 AM
  14. Vishnu Mishra's Avatar
    Hello Vivek,
    My note 3 Wifi is half lit, did u have the same problem ?
    Thanks
    Vishnu
    10-01-2016 11:46 AM
  15. Vishnu Mishra's Avatar
    Hello Vivek,
    Thanks
    Vishnu
    10-01-2016 11:46 AM
  16. Bassplayer1975's Avatar
    Can you help me with my galaxy note 3 wifi bluetooth issue?
    01-28-2017 04:06 AM
  17. belodion's Avatar
    Welcome.
    What is the issue?
    01-28-2017 01:09 PM
  18. Pedro Vilarinho's Avatar
    Hi mate, would you be so kind and tell me how did you fix this Wi-Fi greyed out issue?
    02-11-2017 06:07 PM
  19. belodion's Avatar
    There are several unanswered appeals for help so it may be better to look in the Samsung Galaxy Note 3 forum, where there are several wifi-related threads which may help.
    ChromeJob likes this.
    02-12-2017 11:15 AM
  1. Replies: 3
    Last Post: 11-06-2014, 12:39 PM
  2. Replies: 12
    Last Post: 11-06-2014, 07:53 AM
  3. Why wont my Galaxy S5 send messages over wifi or the network?
    Last Post: 11-05-2014, 02:08 PM
  4. Replies: 1
    Last Post: 11-05-2014, 11:44 AM
  5. issue with note 4 and android central app
    By droid747 in forum Samsung Galaxy Note 4
    Last Post: 11-05-2014, 08:49 AM
