1. wabbit3119's Avatar
    I went to try to move my google search bar to the other side of the screen, and it didn't eork, so i out it into the tab that you pull up for the applications, and it turned red and had a trash can logo on it, i out it in there thinking i could transfer it to the other side, but now i don't have it anywhere, is there any way i can get it back?
    08-21-2009 05:07 PM
  2. anon(697)'s Avatar
    Choose to add a new item to the screen, select to choose from Widgets and select the Search Widget.
    08-22-2009 08:49 AM
  3. larrygump's Avatar
    exactly!!!! you need to play with it man
    09-01-2009 04:41 PM
