1. frankp007's Avatar
    Why can't i access Wi-fi or data on my Samsung Galaxy Duos phone?
    I am not able to connect to my wifi network as it keeps telling me that the authentication failed. Although, the wifi key is correct as im connected to the same network on other devices in the house.
    I can't even upgrade my OS as i can't connect to the internet.
    Any thoughts? or Fixes???
    Cheers
    11-11-2014 07:13 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you clarify--is it only wi-fi that is having problems, or wi-fi and mobile data (3G/4G)?
    Review this guide and see if the tips help: http://forums.androidcentral.com/amb...-problems.html
    11-11-2014 03:39 PM
  1. Replies: 13
    Last Post: 03-12-2015, 04:33 PM
  2. "can you park?"
    By inderhayer in forum Android Games
    Last Post: 12-29-2014, 01:11 PM
  3. How can i transfer non movable apps in my gn8 N5120 to sd card?
    By Raven Cruz54 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 11-14-2014, 09:56 AM
  4. Where should i buy my Galaxy s4, is galaxy s4 the best option ?
    By Nathan Nan in forum Samsung Galaxy S4
    Last Post: 11-11-2014, 09:58 AM
