1. amanduhleigh4484's Avatar
    my phone is on the couch. if i move around it without touching it the screen turns on and shows the time and the lock circle.
    is this a glitch with the phone or is there a setting i can turn off?
    11-11-2014 05:16 PM
  2. srkmagnus's Avatar
    Check the motion controls. There's something enabled that is causing the device to wake when it's moved, or the devices senses movement in front of the screen. There should be a dedicated app for it. If not, then check the system settings.
    11-11-2014 08:14 PM
  1. Why won't my phone place a call (Samsung S4)?
    By rockinrealtor in forum Ask a Question
    Last Post: 12-28-2015, 10:55 AM
  2. My #1 issue: Inadvertently pressing the sidebar
    By Gsxr151 in forum Samsung Galaxy Note Edge
    Last Post: 11-27-2014, 08:07 PM
  3. Recent switch to Note 4 and love it but...
    By CeeGeeLawrence in forum Samsung Galaxy Note 4
    Last Post: 11-16-2014, 02:44 PM
  4. Sony Repair Screen Replacement Cost
    By acas696 in forum Sony Xperia Z3 Compact
    Last Post: 11-12-2014, 05:26 AM
  5. Why is my Nexus 4 stuck at the loading screen?
    By Kendo12 in forum Google Nexus 4
    Last Post: 11-11-2014, 04:37 PM
