Apps preinstalled?
or at least hide the widget some of the stuff I will never use it is just taking up space and memory.
HELP
HELP
Apps preinstalled?
HELP
Like Chris said, root it. It's pretty easy and there is plenty of help on the forums. After that, you can uninstall anything (including pre-installed bloatware) using Titatnium Backup (which is a must-have root app) or other means.
If you do choose to root your device please make sure that you read through some of the material on how to do it and also how to reverse it, if you haven't already. Better safe than sorry.
I am sure this has been said way too much and is cheesy as anything but.....
WITH GREAT POWER COMES GREAT RESPONSIBILITY!!!
-Uncle Ben
haha I couldn't help myself
