1. Gwendolyn Patterson's Avatar
    I trying to setup my contact in difference groups. When i want to leave a text i have to go to each contact and check them off.
    11-14-2014 12:41 PM
  2. raptir's Avatar
    I don't have the S5 but I assume it's similar to the Note 4.
    Go to contacts, select the contact you want to add to a group, tap edit, then tap groups at the bottom. Add the contacts that you want to a single group. Then, back in your contacts list, tap the "group" button (looks like two people standing in a line kind of), select the group you want to message, tap the menu button and tap send message/e-mail. You can only message ten contacts at once, but you can hit Select All from the send message/e-mail menu to select the first ten.
    11-14-2014 01:25 PM
