1. Erick Valdes's Avatar
    Ok, so today I bought a LG L70 and wanted to connect to my Wi-Fi, but after entering the password the "connect" button doesnt light up (it stay grey instead of black) it seems that the requiered characters to make it able to connect it's 5 and 13 characters, while my house password its 9 characters long, is there any way to make it able to input any lenght password?
    EDITED: My local wi-fi it's WEP, and I have no issues connecting to networks using WPA/WPA2, so this seems to be an issue with WEP only.
    11-14-2014 05:12 PM
  2. courtneyftw's Avatar
    As far as I'm aware, there is no specific amount of acceptable characters when connecting to WiFi networks.. Certainly not 5 characters or 13. Can you take a screen shot for reference?
    11-14-2014 07:26 PM
  3. srkmagnus's Avatar
    I'm pretty sure the above post is correct. What happens when you enter the password and accept? Will it connect?
    11-14-2014 07:42 PM
  4. Erick Valdes's Avatar
    Why isn't the length of my password letting me connect to my wifi LG L70?-screenshot_2014-11-14-18-27-28-1-.png
    As you see it doesnt let me click the connect button, only when the length its 13 or 5 characters, thats for a WEP network, if I try to connect to a WPA2 SPK it allow me to enter more than 8 characters
    Attached Thumbnails Why isn't the length of my password letting me connect to my wifi LG L70?-screenshot_2014-11-14-18-18-50-1-.png
    11-14-2014 08:01 PM
  5. Rukbat's Avatar
    1) The specs are:
    For a 40 bit WEP network, always choose a 5-character password.
    For a 128 bit WEP network, always choose a 13-character password.
    The password (40 bits or 104 bits) then has a 24 bit random number added to it, to make a 64 bit or 128 bit passkey. (Why 64 bit is called 40 and 128 bit is called 128 is something I don't know, since I wasn't involved in the 802.11 standards.)
    Some equipment allows you to enter any password, then hashes it to 5 or 13 characters, to allow it to work (it's called cheating). That's probably what your other equipment is doing. Evidently Android just follows the specs and requires a 5 or 13 character password.
    2) WEP is about as secure as locking your door by "gluing" wet tissue paper over the crack between the frame and the door. It can be broken in about 30 seconds by a lot of available apps (and has been that insecure for almost 5 years now). About all it does is make people try to break into it. (Then they do things like connect to computers on the network and format drives - that's the same mentality that writes viruses.) Use at least WPA2/Personal. You want a lock, not an invitation.
    Erick Valdes likes this.
    11-15-2014 01:25 AM
  6. Haimm's Avatar
    I have the exact same issue that Erick mentioned.
    So, is there anything I can do to connect my Wi-Fi?
    Haim
    06-22-2015 04:30 AM
  1. Does the Droid Turbo work with the Square credit card reader?
    By Jodi Longobardo in forum Motorola Droid Turbo
    Last Post: 02-22-2016, 06:58 PM
  2. Do you have the Incipio case?
    By billbrobaggins in forum Motorola Droid Turbo
    Last Post: 01-15-2015, 09:20 PM
  3. Samsung blocking of bootloader is an abuse
    By fredrikwe in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 11-15-2014, 02:09 AM
  4. What does Verizon PRI Version refer to?
    By Don Cordell in forum Ask a Question
    Last Post: 11-14-2014, 05:42 PM
  5. My At&t galaxy note 1 won't boot up.
    By rolando rivera in forum AT&T Galaxy Note
    Last Post: 11-14-2014, 05:24 PM
