1. Raed Salhab's Avatar
    I bought Huawei Ascend P6 T00 from China, when I returned to Jordan the mobile could not connect to 3G but connected to 2G, after doing a search I found out that this mobile has "Frequency Band":
    TD-SCDMA A BAND: 2010-2025 MHz
    F BAND : 1880-1920MHz
    GSM: 900MHz/1800MHz/1900
    While in Jordan the 3G frequency is 2100 MHz.
    So it is possible to change the frequency of the mobile to be 2100 MHz?
    Regards
    11-15-2014 08:28 AM
  2. Rukbat's Avatar
    By changing the motherboard. Which, if you can't do it yourself, will be more expensive than selling the phone on Swappa or eBay and buying a Jordanian phone.
    11-15-2014 03:43 PM
  1. Anyone have any success tethering a Note 3 to a Tab S?
    By Bryan2014 in forum Ask a Question
    Last Post: 11-15-2014, 03:28 PM
  2. Nexus 7 vs Nexus 9, which to get?
    By SwiftHax in forum Google Nexus 9
    Last Post: 11-15-2014, 01:53 PM
  3. Replies: 2
    Last Post: 11-15-2014, 10:01 AM
  4. Replies: 1
    Last Post: 11-15-2014, 09:06 AM
  5. Replies: 4
    Last Post: 11-15-2014, 08:25 AM
