1. Ellol91's Avatar
    i accidentally wiped everything with twrp (system, data, cache, ...) i checked them all
    now when i try any command on the prompt command like adb smthng or fastboot smthn it give the message adb (or fastboot) is not recognized as internal or external command, operable program or batch file !!
    my phone is/was rooted and my bootloader is unlocked and i've a nexus 5
    no adb/fastboot aren't working !! that's my biggest problem for now !!
    11-16-2014 06:38 PM
  2. ljxdaly's Avatar
    i am NO pro, but i did this exact thing with my galaxy nexus some time ago. some fellow over at xda talked me through it. here is a link to that thread.
    [Q] newbie in over his head | Samsung Galaxy Nexus | XDA Forums
    a few things jump out at me:
    first, your recovery should still be there. so that is good, even if you don't have anything to install.
    second, adb/fastboot would still work....if you can figure out how to install the correct drivers on your pc. please don't ask. i am a driver dunce, but that is what i've been told.
    third: the nexus root toolkit by wugfresh, if you go through it precisely, should get you up and running. there is an item in the toolkit that will lead you through the driver installs.
    here is a link to NRT.
    Nexus Root Toolkit v1.9.7 | WugFresh
    i hope you can get it working.
    11-16-2014 07:03 PM
  3. Ellol91's Avatar
    no adb/fastboot not working ... that's my biggest problem now !!
    11-16-2014 08:19 PM
  4. ljxdaly's Avatar
    that may or may not be true. tough to say with the wealth of information you've provided.
    did you even look at the links i posted? sort of sorry i took the time.
    11-17-2014 09:38 AM
  5. srkmagnus's Avatar
    You need to reinstall the drivers and the sdk (to be safe) and try flashing the latest factory image. That will get you back up and running. The device should still have access to fastboot.
    Let us know how it goes.
    11-17-2014 02:41 PM
  6. trbcop's Avatar
    Twrp should still boot up, I did the same just now.
    My problem was fixed from doing the following:
    Reboot into recovery (from twrp, i did not reboot the phone as i knew i made a mistake)
    copy necessary files to phone using android file transfer such as
    vendor img
    rom
    gapps
    supersu
    flashed in that order and now everything is back to normal.
    Hope this helps you & others
    03-06-2017 08:50 AM
  1. S Note Data Recovery from Cracked S3 Mini
    By Ruby Sun in forum Samsung Galaxy S3 Mini
    Last Post: 03-11-2015, 04:12 PM
  2. Replies: 3
    Last Post: 11-22-2014, 05:36 PM
  3. What is wrong with my phone?
    By Sidney Henry in forum Ask a Question
    Last Post: 11-18-2014, 10:06 AM
  4. Why won't my LG Optimus l70 power on?
    By Gage Monceaux in forum Ask a Question
    Last Post: 11-17-2014, 01:33 AM
  5. How can I root a Kindle Fire HDX 7 with new update?
    By ChrispyT2 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-16-2014, 05:22 PM
