1. Kathy Reznak Moseley's Avatar
    Apps don't work. Try to open goes back to home screen or black one. Games don't work. Facebook doesn't work properly. this didn't load right or is full of bugs. How do I go back to the previous system?
    11-19-2014 12:23 PM
  2. metle_geek's Avatar
    Is this an official ota? If not you might have gotten an alpha build or one that wasn't ment for your nexus 7 did you not backup your KitKat rom?
    11-19-2014 12:50 PM
  3. fed123's Avatar
    Try a factory reset. It worked wonders on my 2012 Nexus 7.
    Sent from my Nexus 7 using Tapatalk
    11-19-2014 04:48 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Do you have a 2012 or 2013 Nexus 7? Before you consider a factory reset, try wiping the cache partition, which won't erase any personal data: http://forums.androidcentral.com/goo...tion-wipe.html
    11-20-2014 12:58 AM
  5. Kathy Reznak Moseley's Avatar
    This was an official update that came to my Nexus 7 tablet to download.
    11-22-2014 03:19 PM
  6. Kathy Reznak Moseley's Avatar
    Did you loose data that was on the tablet? I can not even get into it to see when the last back up was.
    11-22-2014 03:21 PM
  7. B. Diddy's Avatar
    Try the cache partition wipe, as I mentioned above. You will not lose personal data with this procedure.
    11-23-2014 12:41 AM
  8. metle_geek's Avatar
    Might be the winning ticket when going from kit Kat to lollipop remember if you stuck with dalvic art is the new caching system so if you still have a dalvic cache delete it and it should boot up as android is updating (which is re writing dalvic to art) so hopefully your good to go!!
    12-21-2014 12:35 PM
  1. Replies: 159
    Last Post: 11-27-2014, 01:10 PM
  2. Why is the compass on my Android 4.4.2 phone stuck?
    By billyqadir in forum Legacy Android & Other OS's
    Last Post: 11-20-2014, 11:13 AM
  3. Why aren't online videos downloading on my device (S3)?
    By Najeeb Jalaludeen in forum Samsung Galaxy S3
    Last Post: 11-19-2014, 07:48 PM
  4. Why aren't online videos downloading on my device (S3)?
    By Najeeb Jalaludeen in forum Ask a Question
    Last Post: 11-19-2014, 03:01 PM
  5. Replies: 0
    Last Post: 11-19-2014, 11:15 AM
