1. Thomas Hart2's Avatar
    If I reset my phone to factory settings will it fix this problem?
    11-20-2014 11:45 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! There are a few things you could try before going to a hard reset:
    1. If you have an SD card inserted, unmount it (in Settings>Storage), remove it, then reboot. A corrupt SD card can impact performance.
    2. Try uninstalling apps that you never use.
    3. Also try disabling any preinstalled bloatware that you never use--go to Settings>Apps>All, select the app in question, and tap Disable. You can always re-enable it if disabling it causes any issues.
    Unfortunately (and oddly), your phone doesn't allow Safe Mode (which prevents all 3rd party apps from starting up, and can be a helpful troubleshooting method). Safe Mode Android | Verizon Wireless. It also doesn't allow access to the Recovery Menu in order to clear the system cache partition, which can also be helpful sometimes.
    11-20-2014 11:51 AM
  1. LG G2 - Best phone I've ever had?
    By 3m1100 in forum LG G2
    Last Post: 04-01-2015, 01:58 PM
  2. How Long Will I Wait for Lollipop on the LTE Version?
    By swebb in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-23-2014, 03:45 PM
  3. Why is my network giving me problems?
    By Muzzammil Muhammed in forum Ask a Question
    Last Post: 11-20-2014, 12:04 PM
  4. Why i cant change my ringtone?
    By Samaranda in forum Ask a Question
    Last Post: 11-20-2014, 11:57 AM
  5. Accidentally deleted 'Phone' icon on Galaxy S5. Help!!
    By anaelenaah in forum Ask a Question
    Last Post: 11-20-2014, 11:52 AM
