1. ShaggyKids's Avatar
    I was texting with my daughter one day several months ago and one te she sent me all it says is "emailed.
    Now every time I send her a text this same text pops up and I have to clear it each and every time I from my notification slider bar. It does not show up amongst any new text I have to scroll back through months worth of texts to find it it seems.
    How do I get rid of this thing? Thanks!
    11-21-2014 01:05 PM
  2. anon(5600632)'s Avatar
    Try Settings-Applications, select your messaging app and clear the cache. DO NOT CLEAR DATA or you will lose all of your old texts.
    11-21-2014 04:55 PM
  3. radicchio's Avatar
    Just curious, if you do clear data in your messaging app, does it clear anything other than texts? I don't usually hang onto my texts for long, so it might be a convenient way to erase them all---but only if there are no other unexpected repercussions.
    11-21-2014 08:08 PM
  4. ShaggyKids's Avatar
    Thanks KCA I just did that so we'll see if that helps.
    11-21-2014 11:02 PM
  5. ShaggyKids's Avatar
    Didn't help. Even cleared the default Messenger cache. Anyone got any other ideas?
    11-23-2014 07:39 AM
  1. Replies: 7
    Last Post: 11-26-2014, 09:22 PM
  2. LG G2 Keeps vibrating for no reason
    By Sushiiii in forum General Help and How To
    Last Post: 11-21-2014, 11:06 PM
  3. Dumb question: how do I keep the phone from ringing at work?
    By Crunchyhippo in forum Samsung Galaxy S4
    Last Post: 11-21-2014, 01:43 PM
  4. Why does my Message App (Standard one) keep freezing then crashing?
    By William Pfaffe in forum Samsung Galaxy S2
    Last Post: 11-21-2014, 01:19 PM
  5. Replies: 0
    Last Post: 11-21-2014, 12:21 PM
