1. dookieshooter's Avatar
    when any kind of audio is being played back, if I unlock or wake the screen the audio is interrupted/paused. This occurs when playing back audio through the phone's speaker, bluetooth, or headsets.
    I have also noticed that it sometimes makes the same sound as when I start Google Now/Voice search, but not always. I have some programs like Media Button Router that are being impacted because their text to speech outputs are being silenced whenever they wake up the phone.
    I have gone through and disabled app after app using titanium backup, but haven't found the culprit yet.
    Screen lock sounds are disabled as well.
    Even things like audio control of the alarm no longer work properly because the audio is being interrupted when the screen is woken up.
    any ideas?
    11-22-2014 10:53 AM
  2. srkmagnus's Avatar
    Are you using a custom ROM? I'd suggest a factory reset or restore to another ROM (stock) if you are using something else. This will give you something to compare to, and see if it's ROM related or possible something else installed on the device.
    11-22-2014 10:22 PM
  3. dookieshooter's Avatar
    I'm on the stock rom, just rooted.
    i was hoping to avoid a factory reset, but I suppose I have everything backed up with TB and can also do a nandroid...
    11-23-2014 08:40 AM
  1. Replies: 3
    Last Post: 11-23-2014, 06:04 AM
  2. Battery saver is orange all the time
    By llanita in forum Legacy Android & Other OS's
    Last Post: 11-22-2014, 09:58 AM
  3. Flashed Lollipop using Wugfresh - now storage amt is wrong...
    By mellyf in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-22-2014, 09:50 AM
  4. Samsung is making a Wi-Fi version Gear S
    By aitt in forum Samsung Gear S
    Last Post: 11-22-2014, 09:49 AM
  5. Q: Cast screen to a PC (full screen)?
    By acegolfer in forum Ask a Question
    Last Post: 11-22-2014, 08:39 AM
