1. Greg Liotta's Avatar
    Has anyone experienced problems with Google Maps on Android (Galaxy Note 3) after the most recent update (Nov. 2014)? Since the update a week ago, Navigation is screwy, I can't rely on it. Any help out there?
    11-22-2014 07:10 PM
  2. srkmagnus's Avatar
    Is there anything in particular that is wrong with navigation? Provide an example so we can try problem solving. A catch all fix is to go into system settings - applications - sort by all - maps. Clear cache from the app settings and try it again.
  3. srkmagnus's Avatar
    11-22-2014 10:55 PM
  1. Connection problems since updating to 4.4.4
    By ccardiff in forum Samsung Galaxy S4
    Last Post: 12-16-2014, 06:05 PM
  2. The 10 most annoying Android 5.0 Lollipop problems solved
    By Shilohcane in forum Google Nexus 5
    Last Post: 11-24-2014, 11:58 AM
  3. Why can't I get Google Play to load?
    By Androidyguy in forum Ask a Question
    Last Post: 11-23-2014, 01:41 PM
  4. Could I have a corrupt Micro SD Card?
    By rep97 in forum Ask a Question
    Last Post: 11-22-2014, 10:50 PM
  5. Replies: 0
    Last Post: 11-22-2014, 06:18 PM
