1. ShreddinPB's Avatar
    Hi guys.. I recently got a samsung galaxy, and sadly there is no marketplace on it.. I cant seem to find any information on how to add the marketplace to my installed android
    08-28-2009 02:27 PM
  2. larrygump's Avatar
    from what I can tell there is no way to DL it....ill keep looking
    09-01-2009 04:01 PM
  3. ram_sg's Avatar
    Slightly off-topic, but is there any app that can 'simulate' a marketplace? * Just wondering *
    rdubmu likes this.
    09-23-2009 01:08 PM
  4. anon(697)'s Avatar
    Still confusion about why some Galaxy's have the Market and some don't - a very odd move from Samsung I think.
    You can download apps from SlideMe (SlideME | Android Community and Application Marketplace). To install them you need to make sure the option is ticked to allow you to install non-market apps (under settings on the phone), then transfer the .apk file to your SD card over USB, then use a file manager to install it.
    I'm not quite sure how you install the file manager in the first place :-)
    Dave
    09-23-2009 01:14 PM
  5. vovkab's Avatar
    Download and install android SDK from developer.android.com/sdk/1.6_r1/index.html
    Then write adb install <path_to_your_apk>
    09-24-2009 08:23 AM
