Concerns about buying an Android netbook
Hello, fellow Android lovers!
I am looking to buy a cheap Android netbook to use, as your grandfather would say, just to access the internet, etc. My current laptop cannot be moved, as the battery does not hold charge (it is a nine-year old HP laptop). My only concern is, four years ago I bought an Android tablet, however the WiFi range on it could not even go the ten metres in my lounge, let alone upstairs, and I live in an average-sized house.
So my question is this.
The specifications given are:
OS: Android 4.1
CPU: WM8850 1.5Ghz
Display: 6.98" TFT
Resolution: 800 x 480
Memory: DDR 512MB
Device storage: 4GB (Supports Up to 16GB via SD Card)
LAN: 10/100M Ethernet Access(RJ-45)
WiFi: 802.11b/g
Keyboard: Standard QWERTY 80 Key US Keyboard and Touchpad
Audio: Built in Stereo Speaker & Microphone, MP2/MP3/WMA/OGG/AAC/M4A/MA4/FLAC/APE
Video: HD 720P,3GP,MPEG1/2/4,FLV,MJPG,H263,H264
Image: JPG,BMP,PNG,GIF
EBook: TXT,CHM,UMD,PDB,PDF
Power adapter: AC 100 - 240V, DC 5V 2A
Language: As Per Standard Android Languages.
And I would like to know whether these specifications mean the WiFi could connect to a BT Home Hub 3 router in an average sized house without any problems like I had with my Android tablet. I compare the 802.11b/g with the specification given on my WiFi adapter I use for my PC upstairs, and it gives the same number, albeit with IEEE at the beginning and /n/2.4GHz at the end. So, my assumption would be it'd be as powerful as my WiFi adapter that works perfectly, I am just asking one of you Android experts to confirm.
Thanks in advance,
- Joe.
OS: Android 4.1
CPU: WM8850 1.5Ghz
Display: 6.98" TFT
Memory: DDR 512MB
WiFi: 802.11b/g
Thanks in advance,
- Joe.
