1. omega13lives's Avatar
    I have a Droid Maxx and tried rebooting, tried clearing its cache and Force Stop, Disable/Reenable, reboot but it's still invisible. I can't add it again because it's running. How to fix this?
    11-26-2014 11:41 AM
  2. B. Diddy's Avatar
    The Command Center is a widget, isn't it? Are you sure you just didn't mistakenly remove the widget from the homescreen? What happens if you long press an empty area of the homescreen, select the option to add a widget, then add the Command Center back to the homescreen?
    11-26-2014 12:28 PM
  3. omega13lives's Avatar
    When I try to long press (in the blank space), it brings up the wallpaper options. When I try to add the widget, it says it is already running, or can't add 2. If I go into Apps I can see it is running, just not visible.
    11-26-2014 12:38 PM
  4. B. Diddy's Avatar
    Does a reboot help? If not, you may have to go to Settings>Apps>All, select the Launcher (it might also be called Home or Homescreen), and Clear Data. This will wipe the homescreens, so you'll need to set them up again.
    11-26-2014 02:27 PM
  5. omega13lives's Avatar
    No, Reboot did not help. I have seen someone else mention that Clear Data fix and hoped I wouldn't have to. If I can't figure out something else, I guess I will.
    11-26-2014 08:10 PM
  6. B. Diddy's Avatar
    It doesn't take too long to set up your homescreens again. Just make a note of how they're set up now, which will make it easier to set them up again.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    11-26-2014 09:25 PM
  1. Is 32gb enough for you guys?
    By johnnnnnymtl in forum Google Nexus 6
    Last Post: 11-09-2015, 01:08 AM
  2. What's New is Gone?
    By katmandoo122 in forum Sony Xperia Z3
    Last Post: 12-09-2014, 09:12 PM
  3. Replies: 1
    Last Post: 11-28-2014, 04:16 PM
  4. Replies: 4
    Last Post: 11-26-2014, 04:36 PM
  5. How is the Galaxy S5 compatibility with ATT LTE?
    By robhir in forum Samsung Galaxy S5
    Last Post: 11-26-2014, 02:24 PM
