1. oblivion64's Avatar
    I bought the Huawei Honor 6 about a month ago and it's an excellent phone. About an hour ago it felt seriously hot and I realised it had shut down. Now I can't turn it on, and when I plug in the charger nothing happens. When I connect it to my computer it makes a sound recognising something has been connected but nothing else.
    The phone doesn't have a removable back from what I can tell.
    11-29-2014 05:40 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you tried pressing and holding the Power button for at least 15 seconds?
    It's possible the battery is defective and failed. Worst case scenario is the motherboard failed You may want to try bringing it back to the store where you bought it and see if they can help you with a replacement. Otherwise, you may have to contact Huawei for warranty repair or replacement.
    11-29-2014 05:53 PM
  3. oblivion64's Avatar
    Thank you for your response. I tried turning it on many times, and held it for 10 seconds probably in an effort but then I decided to hold the power button down even longer and it actually turned on. I came back on here to delete this question but just wanted to say thank you for your answer anyway, I appreciate it.
    B. Diddy likes this.
    11-29-2014 06:04 PM
  4. B. Diddy's Avatar
    Great! I'm not sure why this has to be done sometimes to power on a phone.
    11-29-2014 07:04 PM
  5. Rukbat's Avatar
    It's the equivalent (almost) of a battery pull.
    But a month old phone? You already know what I'm going to say, right? "Bring it back."
    11-29-2014 11:19 PM
  6. Wazir Khan1's Avatar
    Even I had to face this problem. My phone was not starting !! not sure why
    Then i came to this forum and tried holding Power button for atleast 15 seconds . It worked
    Yay !! you guys saved me from travelling 10km to service centre on a weekend
    04-03-2015 05:15 AM
  7. mary liu1's Avatar
    I have the same problem. I bought it 3 month ago. It is automatic shutting down without notice. I have to turn on for holding the power button at least 10 seconds. Huawei can fix this problem?
    06-26-2015 10:41 AM
  8. Ravi Carpenter's Avatar
    Thanks. My phone was not starting. After reading your answer and pressing for around 12 seconds, it started.
    Thanks for you help.
    You'd appreciate that I registered with this site just to thank you.
    08-19-2015 10:18 AM
  9. Bhupendra Negi's Avatar
    Thx my phone ws also not starting after its battery got dead. I almost lost hope. Thx to Google devta it brought me here. Thx to B Diddy I pressed it for 15 sec and it came bk to life with 1% battery.
    09-17-2015 09:26 PM
  10. Nurin Tee's Avatar
    Thanks.
    11-19-2015 11:54 PM
  11. Brandon Ho033's Avatar
    I already press the power button for 15 sec but it just gives me a short vibrate and nothing happened.I hope you can help me asap thanks.
    Ahmed Bohaimed likes this.
    08-29-2016 11:44 AM
  12. KzTech's Avatar
    If it vibrates when plugged in computer there's a chance of reviving by flashing the device. If you are willing to do so, I'll gladly help.
    09-09-2016 03:39 PM
  13. Brandon Ho033's Avatar
    It vibrates when I charge the phone.I already this many times still doesn't work
    09-14-2016 04:29 AM
  14. 18061992's Avatar
    thank you very much. had the same problem this morning when my phone wasnt charging or switching on. i held it for about 12 seconds and it switched on. thanks for this forum
    10-04-2016 01:42 AM
  15. angelo27's Avatar
    your response on holding for 15 sec did not work so I will send back to 3 tomorrow.
    11-27-2016 02:08 PM
  16. Ahmed Bohaimed's Avatar
    I got the same proplem did you find any solution ???
    01-18-2017 04:54 PM
  17. pavan kumar t p's Avatar
    Thanks for the solution. I had the same problem. I had bought honor 6 around 15 months ago. It was not working since this morning. now after holding the power button for around 12 seconds, it switched on. I was really worried since i bought online and the mobile is beyond manufacture warranty.
    02-09-2017 12:08 AM
  18. Reyneveld Leon's Avatar
    my phone cant on.I already press the power button for 15 sec but no vibrate at all.its happen aftr i shut down my phone.and now i cannot on it. anthing i can do?
    10-12-2017 01:33 PM
  19. Lollypopking7456's Avatar
    I have a Huawei 6A that has seemed to stop working all of a sudden it is my spare phone that I let my brother borrow and when I got it back it won't turn on I plug it in to charge it and all it does is constantly viberate I did a factor reset on it not long ago (today) but my brother says it has been in this state for some time does anyone know what is wrong with it please help
    08-02-2018 05:45 PM
  20. Vincent Mugambi's Avatar
    This actually works. I initially thought my phone was hard bricked. I held the power button for 15 secs and it booted.
    01-21-2019 02:01 PM
  1. My heart rate was 178 while testing out walking on GPS today
    By thegame161 in forum Samsung Gear S
    Last Post: 11-29-2014, 09:58 PM
  2. Automated On/Off for WiFi Calling
    By kct1975 in forum HTC One M8
    Last Post: 11-29-2014, 08:34 PM
  3. Note 3 - spilled liquid on phone, screen not working - please advice
    By BlueOrbit in forum Samsung Galaxy Note 3
    Last Post: 11-29-2014, 07:51 PM
  4. Replies: 1
    Last Post: 11-29-2014, 05:56 PM
  5. Why won't my Galaxy S2 go to home screen?
    By hgu1 in forum Samsung Galaxy S2
    Last Post: 11-29-2014, 04:43 PM
