1. Sylvieu's Avatar
    The port to my year old s3 is a bit messed up and when it's plugged in to charge, although it's loose it usually charges fully. But recently, my phone has refused to charge or it charges but very very very slowly. It's been at 6% for 3 days now, even when I'm charging it. Also 3 days ago, while it was charging overnight, I woke up the next day to read that it was fully charged only to see it go down to 12% as soon as I unplugged it.
    12-01-2014 01:51 PM
  2. UJ95x's Avatar
    Welcome to AC
    Sounds like you either have a bad battery, a bad charger, or both. If you've had your phone for a long time, it's probably the battery so I'd recommend getting a new one (they're fairly cheap on Amazon/eBay).
    12-01-2014 01:54 PM
  3. Mooncatt's Avatar
    Agreed. If it shows full and drops very quickly instantly when unplugged, or doesn't charge at all when plugged in, it's a good chance the battery is bad. Other things could cause similar symptoms, but since you're setting both, I'm inclined to suspect the battery itself.
    12-01-2014 02:00 PM
  4. Sylvieu's Avatar
    Welcome to AC
    Thank you. Haha.
    UJ95x likes this.
    12-01-2014 02:16 PM
  5. Sylvieu's Avatar
    Thanks.
    UJ95x likes this.
    12-01-2014 02:16 PM
  1. My phone froze and now won't turn on anymore?
    By MacaroniUK in forum Samsung Galaxy S3 Mini
    Last Post: 02-11-2015, 04:36 PM
  2. Replies: 12
    Last Post: 12-05-2014, 01:06 PM
  3. Replies: 5
    Last Post: 12-02-2014, 12:50 AM
  4. Replies: 6
    Last Post: 12-01-2014, 05:21 PM
  5. Can anyone help me activate my Sprint Galaxy S3 on MVNO?
    By joe_mccarthy in forum General Carrier Discussion
    Last Post: 12-01-2014, 12:17 PM
