1. AlexanderHoward's Avatar
    The long press is well supplied with French of German letters: I also use Icelandic on occasion, and need the letters Þ and Ð. Is there a way to add these to the characters generated from the long press?
    12-03-2014 01:09 PM
  2. SpookDroid's Avatar
    It depends on the keyboard you're using. SwiftKey, for instance, has an option to show all accented characters from your added languages at long-press. Some keyboards will only show those pertinent to the current language that is being used.
    12-03-2014 02:30 PM
  1. How long should the Note 4 quick charging time take?
    By KBlack2595 in forum Samsung Galaxy Note 4
    Last Post: 08-13-2015, 10:56 PM
  2. Oops. Need Help! Android system encryption, too many characters
    By jsaxophone in forum Android Security Talk
    Last Post: 12-12-2014, 10:41 AM
  3. Why is my keyboard showing grey slash marks on each letter after I press it?
    By Kishan_Halai in forum General Help and How To
    Last Post: 12-04-2014, 09:07 PM
  4. Replies: 1
    Last Post: 12-03-2014, 08:46 AM
  5. [Nexus5] Dialer app takes too long to load up
    By fz553 in forum Legacy Android & Other OS's
    Last Post: 12-01-2014, 06:35 PM
