1. donykko's Avatar
    Galaxy S5 - OS still original 4.4.2 rooted.
    Even if I write ascii passkeys to connect to wifi routers, in the wpa_supplicant.conf all passkeys stored are transformed in hex.
    The result is that I cannot recover an original password like I have been doing up to now even with OS 4.4.4 on my previous phones.
    Moreover, I cannot use the hex password to connect to wifi routers because they won't work.
    Thanks.
    12-03-2014 01:53 PM
  2. Rukbat's Avatar
    Look up an ASCII chart on the web. 30 is 0, and the digits go up from there. 41 is A, 61 is a, and the letters go up from there.
    Break the hex into 2 digit groups and translate.
    This is a chart (if you don't mind waiting 2 seconds for the second frame to load - it looks interlaced or something, and it's fuzzy until it finishes loading.)
    12-03-2014 02:06 PM
  1. How can I use Pda.net with my Linksys router ?
    By bikernb in forum Ask a Question
    Last Post: 12-03-2014, 02:32 PM
  2. Why is Gmail draining my battery?
    By mightyfacundo in forum Motorola Droid Turbo
    Last Post: 12-03-2014, 02:17 PM
  3. Can a Sprint S4 be flashed to work on Verizon network?
    By Mnrepoman in forum Samsung Galaxy S4
    Last Post: 12-03-2014, 02:00 PM
  4. How can I turn off some of my apps that automatically synce?
    By Donald Rozenberg in forum Legacy Android & Other OS's
    Last Post: 12-03-2014, 01:52 PM
  5. My settings in voice grayed help.
    By only foryou in forum Samsung Galaxy Note 4
    Last Post: 12-03-2014, 12:40 PM
