1. I2obb's Avatar
    I'm trying to enable USB debugging but my phones LCD is broken and the touch screen will not work.
    Phone: LG G2 Vs980
    I am hoping to mirror the phone on to my computer to answer texts and calls! Thanks and help will be much appreciated.
    12-04-2014 12:15 PM
  2. SpookDroid's Avatar
    Well, you can mirror the screen on a TV via HDMI and do that there, but you'd need a bluetooth mouse/keyboard that's already been paired with your device if your screen is unresponsive
    If your phone is a newer Samsung one, you can use SideSync to mirror the screen on your computer (as long as they're on the same WiFi or via USB) and use the computer's mouse and keyboard as input. However, SideSync must be running on your phone first, so if the touch screen is unresponsive, you could fire it up using Google Now.
    12-04-2014 12:29 PM
  3. Rukbat's Avatar
    The way we do it in a shop is to temporarily plug in a working screen, then do what's needed (copy files, turn on USB debugging, etc.)
    12-04-2014 05:00 PM
  4. Heather Stone2's Avatar
    And how do you do that? my touch screen is completely unresponsive. i have the program i need for using the phone on the desktop, but it won't connect to my phone unless usb debug is turned on, but not being able to see or control the phone screen, i can't turn it on. do you have instructions on how to do that? samsung s4
    03-06-2015 03:08 PM
  5. Rukbat's Avatar
    On using a working screen? That's one of those "if you have to ask, you can't do it" things. You have to take the phone apart and you have to have a G2 (or whatever phone you have) screen lying around.
    Try just plugging the phone into the computer you always plug it into and copying files from the phone to the computer. (If the phone needs authorization for the computer, and it's been connected to it before, you already authorized that computer.)
    03-06-2015 05:54 PM
  1. So much for Gorilla Glass 3 (Broken Screen)
    By sullywagon in forum Motorola Droid Turbo
    Last Post: 09-21-2015, 06:24 PM
  2. Flip Case with Card Slots
    By albie999 in forum LG G3
    Last Post: 12-05-2014, 08:26 AM
  3. Is there wifi calling on the Samsung Galaxy S5 Actvie?
    By MattP82 in forum Samsung Galaxy S5 Active
    Last Post: 12-04-2014, 01:04 PM
  4. How to root Samsung Galaxy S4 Active/SAMSUNG-SGH-I747?
    By KJ ETH in forum Ask a Question
    Last Post: 12-04-2014, 12:57 PM
  5. "Reject call with message" bar
    By Berzelius in forum Samsung Galaxy S3 Mini
    Last Post: 12-04-2014, 11:38 AM
