1. Keith Kay's Avatar
    Trying to know how to save things to my sd card on my phone
    12-05-2014 03:03 AM
  2. Rukbat's Avatar
    That depends on what things. Data from an app - the app has to be written to allow you to choose the storage location. An app itself - some apps can be moved to the SD card - use Application Manager or Link2SD. Be warned - some apps that can be moved won't actually work after they're moved. (The "developer" never tested this, so he didn't prevent the app from being moved.) Pictures, songs, videos? A file manager, like ES File Explorer, MyFiles or Total Commander.
    12-05-2014 06:00 PM
  3. Mooncatt's Avatar
    Unless you're on Kit Kat, then you can't without root, or tether to a computer and use its file explorer to do so. Some phones with a stock OEM file manager can still do this, but not 3rd party apps on KK due to a security change with Android itself. I've seen some references lately that Lollipop allows this again, but I don't have it yet to check first hand.
    12-05-2014 07:13 PM
  4. Rukbat's Avatar
    Any app can write to a folder it owns on any version of Android. It can't write to a folder on the SD card that it doesn't own since KitKat.
    12-06-2014 04:34 PM
  1. Don't Buy Moto X, Very Fragile phone
    By Princecooldude in forum Moto X
    Last Post: 12-09-2014, 01:36 PM
  2. Replies: 3
    Last Post: 12-06-2014, 12:12 AM
  3. Screenshots M8 Screenshots on youtube
    By Tlau927 in forum Ask a Question
    Last Post: 12-05-2014, 09:37 AM
  4. Why won't my Nexus S 4G charge?
    By Raylyn Gilbert in forum Ask a Question
    Last Post: 12-05-2014, 05:34 AM
  5. How do I put stuff on my sd card on my phone?
    By Keith Kay in forum Ask a Question
    Last Post: 12-05-2014, 03:03 AM
