I have changed my LCD resolution using device control with root changing the build prop file. I reset my phone and nothing changed it is still zoomed in I cant do the setup because the keyboard doesn't pop up. So how do I change the build prop back to normal using a computer since I cannot get into setting to change it to MTP what should I do?
So what I'm stuck at is I cant get into the device it is too zoomed in and the MTP isn't set so I cant use a computer to browse the file system to reset the build.prop file
12-05-2014 12:18 PM
