Originally Posted by
Elbasan Shala i want to delete permanently saved preferred network mode on GSM only to be able to use 4G but i cannot because its permanetly saved and any opcion doesnt work
There's a likely possibility your carrier or network provider does not have 4G or 3G or you bought a GSM sim which doesn't support 3G and 4G. If you can see an option to change the GSM to 3G, then your device can change into 3G/4G, but only if its available by your provider. If the option for selecting 3G or changing GSM to something else isn't available, then your device doesn't support 3G/4G. In most cases, GSM is limited to location i.e reserve/rural areas.
