1. Boogaloo Stu's Avatar
    My note 3 running on 4.3 won't permanently delete videos from my sd card. I tried deleting the files almost every way possible and after rebooting, they are right back where they were. I'm considering wiping the phone but I would rather not. I just don't want to run into this again if I end up wiping it. Has anyone run into this and found a solution without restoring back to factory? Please help!
    12-06-2014 10:12 AM
  2. Rukbat's Avatar
    Internal SD or external SD? If external, have you tried deleting the files by putting the card into a card reader and plugging it into a computer? If internal, have you wiped the cache of the app you're using to view the videos? Have you turned the phone's power off since you deleted them? (What's "available" is what's in the Media Scanner database. If you delete a video file, but the name doesn't get deleted from the database, it still shows as available, even though the file isn't there.)
    12-06-2014 11:57 AM
  1. Stock Email App on TMobile Lg G3?
    By stardomains in forum LG G3
    Last Post: 12-07-2014, 11:11 AM
  2. How do I prevent my phone from pocket factory resetting?
    By fridberg in forum Ask a Question
    Last Post: 12-07-2014, 02:31 AM
  3. android wear battery widget on phone?
    By red.foxx15 in forum Android Wear / Wear OS
    Last Post: 12-06-2014, 10:34 PM
  4. On my Nexus 7 2013, why am I getting a Black Screen?
    By jason_sa in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-06-2014, 10:35 AM
  5. Replies: 1
    Last Post: 12-06-2014, 10:07 AM
