How to input photo note in text?
acsurfer
559
18
When looking at a image inside Gallary app in Samsung S4, I can choose menu>photo note, to write a note using the "handwriting" input.
Is it there a way to type a note in text instead of handwriting?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
I don't think there is a way to use the keyboard to input the text. A workaround is to use a Note taking app such as Keep to write the note and upload the picture as a reference.
anon8380037
5,171
Odd you have handwriting on the S4.
If perchance you have a Signature option as well, as on my Note 3, thats how I type on the photo in a supplied box. Photo Note puts handwriting on the back.
From my SM-N9005 Note 3 on Tapatalk
acsurfer
559
18
Thats is a great function. I think it only appears in Note 3, I do not have that in my S4. Is there an app that can do that?
acsurfer
559
18
anon8380037
5,171
Probably not then. I only offered because I was surprised Photo Note was on the S4, so thought Signature would be too.
They maybe changed the terminology for the Note 3.
I would ask or search the S4 forums though. I can't tell without seeing the menus or having one in my hand.
(offline for a few hours)
