1. GoTTi's Avatar
    I have the g900h s5 device that I rooted a little while ago. I want to unroot the phone.
    when I search for my firmware, I am getting confused by the country codes I see on the files. does the country code matter on the firmware?
    when I do the *#1234#, I see:
    ap: g900hxxu1ani1
    cp: g900hxxu1ani1
    csc: g900huub1ani1
    on sammobile I search for g900huub1ani1 and I see 3 countries listed.
    Trinidad and Tobago, Uruguay, panama
    which one do I choose? does it matter?
    12-13-2014 11:31 PM
  2. wizzrah's Avatar
    ap: g900hxxu1ani1
    cp: g900hxxu1ani1
    csc: g900huub1ani1
    Hello. If you are using SuperSU, it has a built in unroot option you can use. Try that first before flashing a firmware.
    12-13-2014 11:36 PM
  3. GoTTi's Avatar
    thanks for the info. I just did that, and when I go to do software update, I get the os system on my device has been modified error. I am assuming I have to restore the phone to original state, I don't know/think the unroot via supersu worked 100%....
    12-14-2014 01:20 PM
  4. Rukbat's Avatar
    It probably did - but you probably ran some rooted app that made some change you didn't "unchange" before you unrooted - and that also stops an update.
    As far as the ROM, yes, the country matters. It has to be the ROM for the same country your original ROM is for. (On some models it won't matter, on some it'll cause the phone to bootloop - it depends on whether there were hardware changes for different countries/carriers for that particular model.)
    12-14-2014 10:27 PM
  5. GoTTi's Avatar
    thanks for the info rukbat...in that case, how do I know what country my device language is based off the data I posted in the first post?
    what do I do?
    12-16-2014 12:38 AM
  6. GoTTi's Avatar
    any help is greatly appreciated
    12-17-2014 07:45 PM
  1. Replies: 30
    Last Post: 05-29-2018, 12:14 AM
  2. Why am I unable to connect to Facebook via home wifi?
    By tasman27 in forum Samsung Galaxy S5
    Last Post: 04-04-2015, 11:02 PM
  3. What to choose?
    By KPSY in forum Ask a Question
    Last Post: 12-14-2014, 12:22 PM
  4. Replies: 5
    Last Post: 12-14-2014, 11:20 AM
  5. Verizon Motorola Droid Turbo Unable to use Google voicemail w/ turbo
    By Billy Bixby in forum Motorola Droid Turbo
    Last Post: 12-14-2014, 12:58 AM
