1. Tita Weng Bay Meris's Avatar
    why is it my Lenovo phone can not detect the installed SD card?
    12-14-2014 07:01 AM
  2. dancing-bass's Avatar
    the SD card may not be formatted properly for your phone to read. Make sure you properly unmount the SD card (you'll see how under "storage" in your phone's settings) and remove it from your phone. Copy any data you have on it to your computer so it's stored safely. Then using your computer, format the card (use NTFS - seems to cause the least issues for me). Once that's done, pop the card back into the phone. Go back to your storage settings, and using the phone, re-format the card. This way you can be sure the phone will see it and use it properly. Once that's done, copy all your data back to the SD card. It is a bit of a pain to go through these steps but it's actually easier then it sounds and will make sure your phone uses the card properly
    12-14-2014 09:23 AM
  3. Rukbat's Avatar
    The phone can't read an NTFS filesystem nativelyk, it needs an app to do that. If the card is 32GB or smaller, format it as FAT32 (which it should be already). If it's 64GB or larger, format it as exFAT (and forgive my jealousy).
    I suspect, however that either the card is defective or the card slot is. If the card works in a computer, it should be recognized by the phone, even if it can't be read. (If you got the card at what seems a very low price for the size and speed of the card, suspect that it's a defective, cleaned and reprinted dud. You can buy "factory refurbished" [not according to the factory, though] 64GB SanDisk Ultra cards for as little as $10 from some vendors. And they really do look like SanDisk cards - until you try to use them. Even the packaging looks authentic.)
    dancing-bass likes this.
    12-15-2014 12:16 AM
  1. Why isn't Twitter compatible with the Note Pro???
    By eobet in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-01-2017, 11:35 PM
  2. Replies: 37
    Last Post: 10-19-2016, 10:56 PM
  3. My experience with a magnetic clip case. DO NOT BUY
    By lpcs1 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 12-28-2014, 06:05 PM
  4. Is there any way to change the calendar format?
    By Rikku Watro in forum Ask a Question
    Last Post: 12-15-2014, 01:22 AM
  5. When was Samsung Galaxy S (the first one) released?
    Last Post: 12-14-2014, 04:56 PM
