1. roundbrackets's Avatar
    According to the accessibility gesture description triple click/tap should not activate the zoom on the keyboard, but it does anyway.
    This is annoying when when I hit enter or erase repeatedly, and I do that quite often.
    The only way I have found to deal with this is to tap slower when I erase, but that's not really feasible.
    Is there a way to solve this? I need to be able to type without triggering the zoom.
    Thanks
    12-14-2014 03:29 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device do you have, and which keyboard are you using?
    12-14-2014 11:45 PM
  1. VPN on Google play 5.1.11
    By Sad Hero in forum Ask a Question
    Last Post: 12-19-2014, 09:00 AM
  2. customize progress bars on rooted devices
    By Ammar Ahmad in forum Ask a Question
    Last Post: 12-14-2014, 09:23 PM
  3. Need help with folders on app screen s5 mini
    By paulhills4053 in forum Samsung Galaxy S5 Mini
    Last Post: 12-14-2014, 07:49 PM
  4. Replies: 1
    Last Post: 12-14-2014, 06:37 PM
  5. Replies: 0
    Last Post: 12-14-2014, 09:59 AM
