So i was playing a game on my android which requires google play service and thats when i noticed that my phone missing lots of google apps so i went searching for a solution and i happen to try that "gapp" im not sure if i actually did flashed it but i remember clearing eMMC thru factory mode or settings then i opened my phone and it really did installed google settings apps etc but then when i tried to open the google play store it closes immediately same with gmail app and the google play service always stops working so then i cant recall whatelse happen but one thing for sure i installed this flash gordon thing then flashed another "Gapp" zip then it says reboot for changes so i did rebooted it and thats when it started, it always boots to recovery mode. i tried wiping caches etc i tried searching for solution but none solved mine. Can you guys please help me with this? ill owe u my whole life. amd for the record i dont have CWM installed, i only use Android System Recovery and yes my phone is rooted.
12-16-2014 04:32 AM
