1. Scott111's Avatar
    Do I use the google Play store app to find packages of rings tones or where do I download them ? or do I download packages online with PC and then xfer them to the phone with a USB wire ? Thanks
    12-16-2014 09:14 AM
  2. THARD11's Avatar
    If you have the app ES File Explorer you can turn any song on your phone into a ring tone. Open the song with ES click on the menu button and say Set as Ring Tone. BTW it's a free app,.
    12-16-2014 09:19 AM
  3. hallux's Avatar
    I use Zedge for that and wallpapers, though I use my phone in a corporate environment around high-level execs so anything other than a normal ring there would be distasteful. I played around with an alternate ring but it was too quiet on even the loudest volume.
    12-16-2014 09:30 AM
  1. Please help, performance and pin problems.
    By porshacat in forum AT&T Galaxy S III
    Last Post: 04-01-2015, 03:29 PM
  2. Replies: 1
    Last Post: 12-17-2014, 06:57 AM
  3. How do I get Hangouts do default to Google?
    By copasetic in forum General Help and How To
    Last Post: 12-16-2014, 06:28 PM
  4. How can I increase my memory?
    By Sandile Siyaya in forum Ask a Question
    Last Post: 12-16-2014, 10:04 AM
  5. Phone lagging horribly after update
    By stevesredhed80 in forum Samsung Galaxy Note 4
    Last Post: 12-16-2014, 09:08 AM
