1. erasto2323's Avatar
    Hi, I currently have the Samsung galaxy S3 on virgin mobile and this morning it said that there was a new update for my phone. I believe that this might have been the 5.0 update because i was previously on the 4.4.4 or 4.4.3. After it installs it starts booting up however it doesn't boot up to the my home screen like usual. It goes into recovery mode. From there i can choose to reboot system now which i do but then it just reboots to the same page. So basically i am stuck in the recovery page. Is there anything i can do to fix this? Thanks
    12-16-2014 12:34 PM
  2. ab304945's Avatar
    Try doing a factory restore, you can do it in recovery. You will lose all your data. The update could of screwed something up
    It wouldn't be lollipop. The s3 might not get 5.0.
    12-16-2014 12:43 PM
  3. erasto2323's Avatar
    Is there anyway of recovering my data? All i would care about recovering would be the picture files and my contacts
    12-16-2014 12:50 PM
  1. How can I clear space in ROM?
    By Polterry in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-15-2015, 11:56 AM
  2. Why there is no firmware updates for Samsung Galaxy GT19100
    By Vishalbroad in forum Samsung Galaxy S2
    Last Post: 02-14-2015, 03:07 PM
  3. Did I get a lemon or were my expectations too high?
    By vocalist in forum Samsung Galaxy S5
    Last Post: 12-24-2014, 01:02 AM
  4. What is the easiest file manager/cleaner for lg phone?
    By Debbiesue49 in forum Ask a Question
    Last Post: 12-16-2014, 12:21 PM
  5. My galaxy won't turn on all of a sudden
    By Jasmine111 in forum T-Mobile Galaxy S II
    Last Post: 12-16-2014, 11:54 AM
