1. takpro's Avatar
    I have 3 Nexus 4 devices. Two are already running the 5.0.1 update as of today. One is still on KitKat 4.4.4. I feel something is amiss. I called Google support and they said just wait. Could someone direct me to the information I need to install the factory image for Lollipop and how to go about it.
    TIA
    Takpro
    12-17-2014 06:05 PM
  2. gone down south's Avatar
    Stock recovery? All system files original and untouched?
    12-17-2014 11:30 PM
  3. takpro's Avatar
    Thank you for your reply.Yes, all stock. I have tried a factory reset several times, but it will not update past 4.4.4.
    12-18-2014 08:39 AM
  4. B. Diddy's Avatar
    This is a pretty good resource: How to manually update your Nexus | Android Central
    12-20-2014 12:45 AM
  5. takpro's Avatar
    Thank you for your assistance, but I could not get the phone to accept any of the commands i.e. ./fastboot oem reboot. I got the SDK downloaded and the factory image extracted to the same folder, but I could not get any of the commands accepted from the CMD.
    12-20-2014 07:51 AM
  6. gone down south's Avatar
    Try the wugsfresh toolkit, that's a pretty foolproof way to get updates on Nexus phones.
    12-20-2014 10:15 AM
  7. takpro's Avatar
    Thank you for your suggestion, I'll give it a try.
    12-22-2014 11:43 AM
  1. 5.1 update coming q1 2015
    By Ian B in forum Google Nexus 6
    Last Post: 01-19-2015, 02:23 PM
  2. Mobile Hotspot Issue Caused by Advanced Calling Update
    By Sean Cogan in forum Motorola Droid Turbo
    Last Post: 12-29-2014, 06:33 PM
  3. lollipop
    By marinho1 in forum Huawei Ascend G6
    Last Post: 12-17-2014, 04:35 PM
  4. 'Media not found' in Photos after 5.0.1 update
    By kroning in forum Legacy Android & Other OS's
    Last Post: 12-17-2014, 02:51 PM
  5. how are updates rolled out
    By baz2011uk in forum LG G3
    Last Post: 12-17-2014, 02:13 PM
