1. Like2HelpingOut's Avatar
    Sorry guys, I don't know how to post guide how so I post question with solution here instead.
    Youtube problems solved
    Go to apps info
    Press turn off and it'll ask you to accept reset to factory with unistall any updates. Press OK.
    Then kill all apps.
    Then back to Youtube apps info.
    Click on force stop.
    Then click on clear data
    Then click on Turn Off
    The click on cleat data again wait til it show 0 kbs
    Then kill apps
    Now go to PlayStore search for youtube
    Click on enable
    Click on update
    Check your Youtube version 6.0.13 now should work properply with resolutions setting.
    Mine was Note 4. Hope this works on all.
    12-17-2014 10:46 PM
  2. Mooncatt's Avatar
    Any idea if this also lets it start buffering an entire video? That's my biggest gripe because I can't pause and let it buffer the entire video before watching. Until I can do that, even 720p may not play without stopping to rebuffer.
    12-18-2014 09:34 AM
  3. AlfieBriggs's Avatar
    Thank you so much! Now watching MKBHD videos in 2K, extra crispy!
    Posted via my sexy Note 4
    12-18-2014 11:06 AM
  1. Which to use: Google Backup or HTC Backup?
    By Raymond Elliott in forum HTC One M8
    Last Post: 12-19-2014, 03:49 AM
  2. Camera Horizon Level + Decent Image Resolution
    By Ezekiel Barbirolli in forum Google Nexus 5
    Last Post: 12-17-2014, 10:25 PM
  3. Replies: 1
    Last Post: 12-17-2014, 09:19 PM
  4. 5.0.1- Bug fix or Bug feed??
    By Manoj Bhaskaran in forum Google Nexus 6
    Last Post: 12-17-2014, 08:51 PM
  5. with exchange now built into gmail, why is there no conversation view
    By Fuzzy761210 in forum Android 5.0 Lollipop
    Last Post: 12-17-2014, 06:37 PM
