1. Riks36's Avatar
    After charging my Galaxy s4, the screen was all pixelated and messed up. It is completely useless. I then noticed a hole in the charger's cable. Could this have anything to do with my phone going nuts all of a sudden?
    12-20-2014 03:08 AM
  2. ch3mn3y's Avatar
    If there was no good protection against higher voltage it could burned part of ur phones mainboard, and if screen depends of this part, its possible that charger broke ur phone.
    Im not sure if warranty covers this kind of damage
    Sent using C6833 - AICP/GreatDevs
    12-20-2014 03:35 AM
  3. AlfieBriggs's Avatar
    Did you use the official Samsung charger?
    Posted via my amazing Note 4 paired with my Moto360
    12-20-2014 06:13 AM
  4. AlfieBriggs's Avatar
    If so, your still inside your warranty I believe, 2yr with every Samsung phone so I'd go in store and tell them that you want it replacing especially if it was the official Samsung charger.
    Riks36 likes this.
    12-20-2014 06:14 AM
  5. Riks36's Avatar
    Yes, it was the official charger. Thanks a lot. Will definitely pay them a visit!
    12-20-2014 08:01 AM
  1. Why does my Galaxy Tab S doesn't find my wifi?
    By David Haubrich in forum Samsung Galaxy Tab S 10.5
    Last Post: 01-09-2015, 03:03 PM
  2. How to recover files from my corrupted mmc?
    By RizwanShehzad in forum Memory (RAM)
    Last Post: 12-21-2014, 03:19 AM
  3. Will i still get my updates?
    By Pooh6369 in forum Ask a Question
    Last Post: 12-19-2014, 11:57 PM
  4. How do I view my data browsing time on my S4?
    By htag330 in forum Samsung Galaxy S4
    Last Post: 12-19-2014, 11:28 PM
