1. Hav4k's Avatar
    Hi.
    I have a smartwatch Mlais or Kingelon K2 that i have updated following this tutorial. Now, i have lost my connection GPS and serial number... what can i do? I tried FasterGPS, but no success.
    h ttp://forum.xda-developers.com/showthread.php?p=57033771#post57033771
    Bye.
    12-22-2014 12:11 PM
  2. srkmagnus's Avatar
    Hi.
    Bye.
    Have you tried a soft reset of the watch? Consider doing that and see if it helps. If it doesn't, then you might need to clear the settings (factory reset possibly) and try it again.
    12-22-2014 07:51 PM
  1. Voice call problem
    By k2ldc10 in forum Verizon Samsung Galaxy S4
    Last Post: 12-28-2014, 02:51 PM
  2. WiFi problem
    By Ryan Stewart4 in forum Ask a Question
    Last Post: 12-22-2014, 07:06 PM
  3. LG G3 Unroot problem
    By MARIO_THE_BEAST in forum Ask a Question
    Last Post: 12-22-2014, 12:03 PM
  4. authentication problem connection to wifi
    By Linda Okonski in forum Ask a Question
    Last Post: 12-22-2014, 08:27 AM
