1. Mewwy's Avatar
    After a day of use, I went to wake my Tab S8 from sleep. Nothing came up, however. The backlight is definitely on and will turn off with a press of the power button, but I can't get it to do anything else. Even the vibration from it acknowledging that the volume has been turned all the way down and into vibration mode is not working. Perhaps shutting it down would help? It had about 50% when this first happened, and I've had it on for the past 7 or so hours, and it still has not died. Help!
    12-26-2014 02:27 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It may be an app that is causing the system to glitch, or a problem with the firmware itself. You can typically force a power off by pressing and holding the Power button for about 15-20 seconds. Then wait a few seconds, and press and hold Power again to turn it back on.
    12-27-2014 04:27 AM
  3. Bill Brooks's Avatar
    Mewy, did you get it working again?
    01-07-2015 09:10 AM
  4. Mewwy's Avatar
    Yeah, I did. After it finally died, it worked just fine after I plugged it in. I wasn't using any form of screen lock so it just would go straight back in to whatever I was using. I haven't had it occur again, and I've been using a password since then just in case that's what was triggering it.
    01-10-2015 09:21 AM
  5. STARGATE's Avatar
    Hey Mewwy, how do you like your S8-50?
    I just got one and been using it all afternoon and part of the night.
    Great display and form factor!
    04-02-2015 11:03 PM
  6. Cezary Skowronski's Avatar
    Hi. I had same issue but after each restart screen is totally black as before was. Any other advice?
    07-13-2015 06:44 AM
  7. anon8380037's Avatar
    Glad you like it.
    Think I may get one this weekend.
    £99 here at a good department store chain with 2 year back up, or online.
    Keep my Moto G in my pocket and use my 4gb hotspot allowance on this. Then worry about getting a Note 4 or 5 later.
    I read some reviews and it's very decent spec.
    I have a Lenovo Thinkpad 14" I like, and now Motorola are Lenovo, lol.
    07-13-2015 08:59 AM
  8. Kelly Tobin's Avatar
    Hi, I'm having a similar issue:
    Please help!
    My sons S8-80 tab touchscreen has become unresponsive.
    I've tried a soft reboot which does nothing.
    A hard reboot doesn't get past the Fastboot Starting screen and just switches off.
    Don't know what else to try!
    09-20-2015 02:41 AM
  9. Aliuska's Avatar
    hola mi tablet lenovo S8 50 LC no encendia. le he quitado la bateria encendio y luego se calento y se volvio a apagar y ahora no enciende ni conectado a la corriente. que hago?
    12-16-2015 07:12 AM
  1. The "safe mode" will not turn off on my phone. How do I fix this?
    By Eitan Lupovitch in forum Ask a Question
    Last Post: 04-14-2016, 01:23 PM
  2. How to move apps to sd card in LG LS620 with Android 4.4.2?
    By Fred Cognil in forum Legacy Android & Other OS's
    Last Post: 01-07-2015, 01:52 AM
  3. Droid Turbo suffered cracked screen despite Otterbox protection
    By Moo Cow in forum Motorola Droid Turbo
    Last Post: 01-02-2015, 11:18 PM
  4. M screen of Death
    By selwinfrogit in forum Moto 360
    Last Post: 12-27-2014, 12:16 AM
  5. Replies: 0
    Last Post: 12-26-2014, 01:26 AM
