problem with sync calendar
I'm having android 4.4.2 rom aosp_v4_leak.17 device: coolpad f1 8297w
in the google account data to sync there are only app data, contacts, google fit & people details, not the calendar
and maybe because of it, the stock calendar doesn't synchronize with my google calendar
I have tried another calendar- same problem
when I installed the google calendar, things work fine, but I don't like this kind of "solution", I want the freedom to select apps at my will
how do I sort this issue?
thanks
thanks
