1. YossiN's Avatar
    I'm having android 4.4.2 rom aosp_v4_leak.17 device: coolpad f1 8297w
    in the google account data to sync there are only app data, contacts, google fit & people details, not the calendar
    and maybe because of it, the stock calendar doesn't synchronize with my google calendar
    I have tried another calendar- same problem
    when I installed the google calendar, things work fine, but I don't like this kind of "solution", I want the freedom to select apps at my will
    how do I sort this issue?
    thanks
    12-31-2014 02:14 PM
  1. Replies: 12
    Last Post: 08-29-2016, 12:30 AM
  2. Which smartwatch works well with the Galaxy Note PRO 12.2 LTE?
    By petercohen in forum Samsung Galaxy Note Pro 12.2
    Last Post: 01-02-2015, 07:09 AM
  3. T-Mo Galaxy Note 3: printing s calendar
    By phart in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 12-31-2014, 01:21 PM
  4. Worth rooting/installing custom ROM with Lollipop right around the corner?
    By TenaciousB06 in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 12-31-2014, 10:57 AM
  5. Perfect Keyboard problem with android 5
    By BrainIcon in forum Android Apps
    Last Post: 12-31-2014, 02:22 AM
