1. ramos19's Avatar
    I follow steps carefully to flash the stock rom on my samsung galaxy trend gt s7560. I am using Odin and S7560XXBNE1_S7560OXXBNF1_S7560XXBNA1_HOME.tar.md5 file. I am stucking at initialization step. Would you please give me advice? <OSM> Check MD5.. Do not unplug the cable..
    <OSM> Please wait..
    <OSM> S7560XXBNE1_S7560OXXBNF1_S7560XXBNA1_HOME.tar.md5 is valid.
    <OSM> Checking MD5 finished Sucessfully..
    <OSM> Leave CS..
    <ID:0/014> Added!!
    <ID:0/014> Odin v.3 engine (ID:14)..
    <ID:0/014> File analysis..
    <ID:0/014> SetupConnection..
    <ID:0/014> Initialzation..
    i switched cables and ports and it still stuck i removed the battery too
    01-03-2015 02:47 PM
  2. Rukbat's Avatar
    Make sure you have the SAMSUNG_USB_Driver_for_Mobile_Phones installed. Even if you think it's installed, install that one. Or the one with the latest version of Kies. they're both the same. (If Kies can see the phone and back something up from it, Odin should be able to flash a ROM.) It looks as if it's trying to initialize the phone but can't. (You are getting a COM number at the top of Odin, aren't you? If not, Odin isn't finding your phone, which probably means that you have no driver.)
    At the very worst, uninstall Odin, reboot and download Odin and install it again.
    01-03-2015 03:16 PM
  3. ramos19's Avatar
    the drivers are installed (with kies) and odin detecte the phone as it appear COM and a number that changes every time i change the port
    ps: on the phone screen there's :
    usb read() transaction failed
    odin : oops!
    01-03-2015 03:28 PM
  4. mohammed289's Avatar
    hey dude did you find a solution at last or no?
    01-21-2016 09:36 AM
  1. Phone stuck on T-mobile screen
    By Rgomez90 in forum T-Mobile Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 04-15-2015, 10:51 PM
  2. Galaxy S3 is stuck on 4.3 - is an update available?
    By gio adeishvili in forum Samsung Galaxy S3
    Last Post: 02-04-2015, 09:49 AM
  3. How do I get my Huawei Ascend y530 out of the recovery screen?
    By Oskars Indans in forum Software Development and Hacking
    Last Post: 01-16-2015, 05:49 AM
  4. Replies: 2
    Last Post: 01-04-2015, 08:54 AM
  5. Replies: 1
    Last Post: 01-02-2015, 10:52 PM
