1. leftcoast2012's Avatar
    Gentlemen,
    I am an iPhone user and is looking to switch and get the Samsung Galaxy Alpha in the coming days. With the iPhone, whenever I have a problem, I just go to the apple store nearby and get it fixed or replaced right away. How does Samsung or other phone manufacturers handle this problem(in the US)? If I get the Alpha and one day it stops working, what do I do to get it fixed or immediate replacement like the iPhone? Sending it in to a repair center out of town and wait for a week or so for repair without another phone is not an option. What do you guys do when this happens to you? Do you go to your phone store (AT&T in my case) to get it fixed?
    Thanks!!
    01-04-2015 11:54 PM
  2. Rukbat's Avatar
    With AT&T it's simple. (Assuming you buy the phone at AT&T - if you buy it at Best Buy and use their warranty, the coverage is a bit better and the copay is lower.) If the phone has a factory defect, bring it to your nearest AT&T Devvice Support Center (Ask your nearest store where it is - it's going to be local unless you live in the boondocks.) If you break something, it's cheaper to pay the Best Buy copay than the AT&T copay - but the difference is that AT&T may have one in stock to give you, while it takes a week or two to get it replaces with Best Buy.
    (With Apple it's easier. They have to have about 6 models for each carrier. With Android there are dozens of models, so even the carrier might not have replacements on hand for every phone. But AT&T is pretty good at working with you to find a solution that works. When one of my phones had to go in for repair, they gave me a free SIM to use with an older feature phone, just so I'd have a phone with me until I got my Smartphone back. That worked for me.)
    leftcoast2012 likes this.
    01-05-2015 12:07 AM
  3. leftcoast2012's Avatar
    ^^That answers my question. Thank you sir!! Off to Best Buy I go. It's $49.99 at Best Buy but $199.99 at AT&T store with 2-year contract.
    01-05-2015 12:38 AM
  1. At 10% Battery phone turns off
    By vaughaag in forum Google Nexus 6
    Last Post: 04-09-2016, 04:26 PM
  2. Replies: 10
    Last Post: 03-02-2015, 01:43 PM
  3. Why isn't my phone connecting to my data network (G900F)?
    By unbiasly in forum Samsung Galaxy S5
    Last Post: 01-07-2015, 01:52 AM
  4. Why is my phone appearing in a blue dead screen?
    By Ren-Ren de Chavez in forum Ask a Question
    Last Post: 01-04-2015, 09:11 PM
  5. Replies: 1
    Last Post: 01-04-2015, 06:20 PM
