Cracked my phone and now my touch screen doesn't work. How do i fix this?
carrieberry1
I dropped a bottle on my LG G2 and the left corner of the screen cracked. I checked it out and the touch screen doesn't work anymore. Can this be fixed? If so how and what do i do/need to fix it ?
SpookDroid
Ambassador
Jul 14, 2011
19,298
549
113
If the crack damaged the digitizer or the connector, that's what you'd need to replace. Glass and digitizer. But unless you're really savvy on this kind of repairwork, I strongly suggest you let a service center do it for you (plus, if they screw that up, they're responsible, not you)
