how to set sd card as location for files. Xperia Z2
I want to set the sd card as the location for a Navionics app that needs a lot of data. I cant find the option to set the file location for any of the apps in settings-apps. In settings-storage it has the option to transfer media to the sd card but that's all. I have a couple of file manager apps but cant figurenout how to do it on those either. Any advice welcome!
Re: how to set sd card as location for files. Xperia Z2
Unfortunately, that's entirely app-dependent. If you want Navionics' app to store its external downloads to the SD card, the app itself needs to support that and include an 'external downloads path' option.
