1. tonyr6's Avatar
    I am wondering if it is okay to have your phone or tablet plugged in while using apps like Netflix, Youtube or streaming music apps like Play Music, Tune-In which drain the battery a lot? Is it okay to have your devices plugged into something like a USB AC adapter or a external battery pack if it will harm the battery?
    01-09-2015 10:39 AM
  2. SpookDroid's Avatar
    It's perfectly OK. It will depend on your charger and how your device handles charging while in-use, however, if you'll see the device actually charge or if it will only discharge slowly (if you ask for more power out of it than what the charger can supply, then you'll see the battery go down, not up). But one of the most common cases of 'use while charging' is, indeed, movie-watching.
    01-09-2015 11:14 AM
  3. Javier P's Avatar
    I agree with Spook. Just make sure your phone doesn't get very hot.
    01-09-2015 11:23 AM
  1. Note n7000 battery draining very fast
    By scoobydoob in forum Samsung Galaxy Note
    Last Post: 01-13-2015, 07:53 AM
  2. Consequences with use of Euro LG G3 in UK?
    By AdRiDev in forum Ask a Question
    Last Post: 01-09-2015, 07:00 PM
  3. Consequences with use of Euro LG G3 in UK?
    By AdRiDev in forum LG G3
    Last Post: 01-09-2015, 06:18 PM
  4. Replies: 4
    Last Post: 01-09-2015, 11:02 AM
  5. How do I change the month on the Lollipop calendar app?
    By shochatd in forum Ask a Question
    Last Post: 01-09-2015, 10:08 AM
