1. anon(7887939)'s Avatar
    I have an LG G3 and every time I am on the lock screen and I cover the sensors (I think it is called the ambient light sensor or proximity I am not sure please help) the screen turns off, even if I use the physical power button and not double tap to wake. It makes it difficult to use while in an arm band case, also when trying to check it while keeping it inside my back pack since it keeps going off until I take it out and unlock it. Any solutions or recommendations to help with this? Thanks
    01-10-2015 05:44 PM
  2. Rukbat's Avatar
    It's probably the proximity detector, working when the phone isn't the foreground app (which shouldn't be happening). It's under warranty, and this is covered, so bring it back. (Make sure you have EVERYTHING backed up - they're not going to fix it while you wait, they're going to replace the phone.)
    01-10-2015 05:48 PM
  3. anon(7887939)'s Avatar
    I live in the middle east and we don't have warranty on our products unfortunately. Could you recommend any other means of approaching this dilemma? Would changing the detector fix this, or is there a software alternative to look into by any chance? Thank you for your help.
    01-10-2015 05:56 PM
  4. Rukbat's Avatar
    The manufacturer should warranty the phone for a certain amount of time. If not, and the sensor is bad (you'll have to determine that), replacing it would solve the problem.
    If it's a software problem (highly doubtful, but possible), the solution would be a software solution.
    Again - you have to determine the cause of the problem before anyone can tell you what to do to fix it. If you can't it has to go into a repair shop.
    01-11-2015 08:27 PM
  1. SMS sounds on Galaxy Note 3
    By Edgar Nava in forum Ask a Question
    Last Post: 01-11-2015, 03:40 AM
  2. LG G3 D855 Phone Cache Wipe
    By Thierry Henry in forum LG G3
    Last Post: 01-10-2015, 07:26 PM
  3. Why will my HTC One connect to the network but not the internet?
    By LaSantaAnaMaria in forum Ask a Question
    Last Post: 01-10-2015, 06:47 PM
  4. How/where do I get a temperature sensor for my Nexus 5?
    By Erik Heyl in forum Ask a Question
    Last Post: 01-10-2015, 05:52 PM
  5. Can i just replace a broken nexus 7 (version 2013) screen?
    By 123android in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-10-2015, 05:23 PM
