1. Holly Gupton's Avatar
    I updated my Samsung Galaxy S4 with knox and every time I open it a window pops up saying the touchwiz home is not working properly and when I click ok it just keeps popping up til I restart the phone.
    01-11-2015 10:43 AM
  2. Rukbat's Avatar
    Have you installed Knox, or do you mean that you updated the ROM and Knox is on it. If the latter, that's just a "stub" to the actual Knox app, which isn't on the phone unless you install it.
    If you need Knox, let the system administrator set it up for you, because different companies use it differently (and that's the only time you need it - in a corporate environment in which you're required to have it on your phone if you want to use your phone on the corporate network - normal users do not need Knox, and it should never have been put on phones by default - Samsung should have sold a corporate version of the phone for AT&T and Verizon that included Knox and a locked bootloader).
    01-11-2015 11:39 AM
  3. ftempel's Avatar
    So, for us who have enable Knox, not knowing what it was about, how do we get rid of the annoying issue. I pull down the notifications screen, see the first item is Knox, tap here to enter Knox mode. I figured if I tap it, I can disable it. No, all I get is the Touchwiz error.
    01-26-2015 07:21 PM
  1. messages and phone app stop working
    By mercuzio in forum Samsung Galaxy Tab S 8.4
    Last Post: 07-06-2015, 01:00 PM
  2. [Kickstarter] [Dock] Indi: The robotic phone dock
    By Willybood in forum Developer Spotlight
    Last Post: 06-11-2015, 03:13 PM
  3. New headphones, sound only out of left ear with S3
    By znh in forum Samsung Galaxy S3
    Last Post: 01-12-2015, 08:43 PM
  4. Using the turbo charged with droid maxx
    By XCalibration17 in forum Motorola Droid MAXX
    Last Post: 01-11-2015, 08:07 PM
  5. Why is finger touch not working in my Galaxy Note SHV E-160 K ???
    By Yogendra Rijal in forum Ask a Question
    Last Post: 01-11-2015, 11:56 AM
