Newbie cant update to Kitkat as there is no update option in settings!
Can anyone help me update my note 2 Clone to the latest KIT KAT version. I have no option to update in the settings so I am stuck on Jelly Bean and want to update. I am sure the phone has been rooted as the Kernel Version says 3 4 0 root at zhangjianan desktop
How exactly do I get Kit Kat onto the phone and could I do it from my pc when the phone is plugged in via usb lead.
Also I want to delete / reset my Tethering and Portable Hotspot usage record from the settings / Data Usage Tab, or change it to a lower number etc.
Is there a way I can go into the phone via the windows explorer when its plugged into the Pc and just delete one log without loosing anything?
I need to get this done as soon as I can and would like to update the phone so I can talk to Google etc like in the adverts...
Please please please can anyone help or point me to a guide that does not involve a you tube video?
CHEERS!
CHEERS!
