1. Angel_Myriad's Avatar
    In my previous tablet I had a very nice lock screen after getting Android 4.4.2. I could see notifications and use widget at the lock screen. But now I've bought this tab s t700 and I hate my lock screen. Instead of widgets it uses cards. But, for example. It does not makes available Spotify widget. I would love to discover if there is a way to get back to how it used to look like before. Does anyone knows how to change it?
    01-19-2015 04:02 PM
  2. greasegizzard's Avatar
    I'd like to know about this myself. I like being able to customize them on my Note 3 lockscreen. Seems hard to believe you can't do it on a more powerful Tab S.
    01-23-2015 11:24 PM
  3. HiiPower's Avatar
    Sadly you can't.. Had the same problem with my Tab Pro 8.4.
    01-24-2015 01:11 AM
  4. Angel_Myriad's Avatar
    I had to install an app. But isn't the same thing.
    01-24-2015 10:35 PM
  1. On the new "slideshow" format we're occasionally using on the blog side ...
    By Phil Nickinson in forum Site Feedback & Help
    Last Post: 04-17-2015, 09:41 AM
  2. Why doesn't Pinch work on my Tablet Vers 4.1.2?
    Last Post: 01-22-2015, 12:05 AM
  3. Triangle away doesn't work on 4.3 jellybean Galaxy S3?
    Last Post: 01-19-2015, 03:56 PM
  4. Replies: 1
    Last Post: 01-19-2015, 03:41 PM
